rear passanger elictric window dosent work
window wont work n/s/r makes noise
Bu iyi bir soru mu?
Bu iyi bir soru mu?
What is n/s/r ? If you hear noise from the motor or the window then the issue is the window regulator itself . Probably the gears are stripped or the window has come off the track . you will need to take the door panel off and inspect the regulator.
This video will help with the removal
https://www.youtube.com/watch?v=MCN_2hcW...
Hope this helps
Bu yanıt yardımcı oldu mu?
N-S-R Near-side rear, passenger side rear
A lot of these cars now have a cable system and plastic parts I've replace a bunch on Chevy and ford
Thank you @mayer
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 96
1 Yorum
Hi Simon, have you checked the fuses?
Blake Klein tarafından
