Ana içeriğe geç
Nintendo DSi, Nintendo DS serisinin üçüncü yinelemesidir ve ilk kez 2008 yılının sonlarında Japonya'da piyasaya sürülmüştür.
Top screen faded with flickering lines
One day, I turned on my DSi and the top screen was faded with what looks like interlacing artifacts always going down the screen. Today, I took it apart, cleaned all of the contacts with 70% isopropyl alcohol and I noticed that the screen works completely fine without the shoulder buttons and SD Card slot (back panel) connected. However, when I plug the back panel back in, the problem appears again. I don't have a lot of knowledge when it comes to electronics so I decided to come here to ask how to fix it. Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hello,
I had the same problem today and discovered, that there are some kind of potentiometers, wich are regulating the screens in some kind. However, you find them if you look on top of the battery. There are two little screws that you can turn to calibrate the screen. The left one is for the lower screen, the right one for the upper screen.
Resim
Sorry for my bad english but I hope that this could help you.
Bu yanıt yardımcı oldu mu?
Puan 11
7 Yorum:
Well, I noticed you posted this back in 2017 so this is pretty much useless.
tarafından
No that worked! Thank you so much I thought it was broken for sure!
tarafından
You´re welkome :)
tarafından
Is this the same for the DSi XL? I opened the batery cover and see two gold screws but no phillips head groove on them. What do i use to adjust them? Thanks.
tarafından
Does this work with the DS Lite model?
tarafından
2 tane daha yorum göster
Yorum Ekle
I thought those were screws and broke the right one by accident .. is there anything I can do about it?
Puan 0
1 Yorum:
Not sure if this is still relevant. but i broke one of them as well. the way i managed to fix it was by replacing the cable those potentiometers are on. i was able to find one by searching for a DSi SD card slot ribbon cable. i was able to get one for about 10$ for reference
tarafından
Yorum Ekle
Yanıtını ekle
Rylan Corral sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 20
Son 30 gün: 102
Her zaman: 13,400
