Ana içeriğe geç
Device and repair guides for the 2016 Samsung Galaxy J5 Prime smartphone, model number SM-G570Y or G570.
J5 Prime Phone will not turn on
So I've had a Samsung J5 Prime for just over 5 months now, and this is the first time it's ever acted up. I didn't charge it over the night, (I forgot) but charged it when i woke up and it was around 60% before I went to school. After about 4 hours of working fine, I went to check the time and my phone wouldn't turn on at all. Held down the power button etc and naturally assumed it had run out of battery. I remember it had about 40% charge left which I thought was a little strange, but I came home and plugged it in.
I've left it charging for about an hour and a half now, but nothing has happened, no red light, no response.
Yes, I checked if the charger was turned on.
I've tried holding down the power button while it's charging
I've tried switching power plugs and chargers
No idea what to do......
Also, the back cover doesn't come off so i cant take out the battery etc.
Bu iyi bir soru mu?
Puan 33
31 Yorum
awesome!!!!!!!!!!!
tarafından
My phone doesn't turn on but the battery/charging indicator is red I've put it on charge for hours now.I've tried soft reboot solution but didn't work.help pls.
tarafından
I've had this problem just a few moments ago. I got the correct answer from one of the comments. Thank you very much for posting the answer.
tarafından
SamSuung J5 Prime is a working time bomb.... Another error!!! While watching a movie, my J5 Prime makes a sound like a lose fan very loud and it hooks and the phone stopped working this is the 2nd time in 2days...
tarafından
Hey my Samsung turns on but it wont show the menu .....it turns on but stucks at the sign SAMSUNG
tarafından
26 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Liz,
You're probably solved this by now - but I just had the same issue. Nothing else I tried worked before this:
I pressed Volume Down + Home Button + Power Button for a few seconds.
After a few seconds I got a turquise screen warning me about a custom OS install.
I cancelled that with a Volume Down press and then my phone booted normally.
Got the idea from here.
Hope that helps Liz (and you future Internet person),
Z:D
Bu yanıt yardımcı oldu mu?
Puan 184
99 Yorum:
Thanks so much for helping out!
You're right - I did end up solving it on my own but thank you anyways
Holding down the home and power button at the same time works as well, (it's called a soft reboot, same as taking battery out on another samsung) that's how mine turned on.
tarafından
this is awesome!! thanks for the great tip! i thought i had to go down to the customer service centre to get the set replaced.
tarafından
my screen is blinking and thats why
i cant rebbot my phone
tarafından
Thank you so much. it helped me a lot after i faced this problem for the first time..:)
tarafından
THANKS a lot dear it works no need to go to repair shop..
tarafından
94 tane daha yorum göster
Yorum Ekle
Charge with original samsung power addapter and cable.
Puan 2
1 Yorum:
omg thank you so much!
tarafından
Yorum Ekle
Yanıtını ekle
Liz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 59
Her zaman: 120,729
