Ana içeriğe geç
Temmuz 2015'te duyurulan bu cihaz, Motorola'nın amiral gemisi telefonudur. 21 megapiksel kameraya ve 1440 x 2560 çözünürlüğünde, Quad HD görüntü sağlayan 5,7 inç IPS TFT LCD ekrana sahiptir. Model numaraları XT1570, XT1579, XT1575 ve XT1578'dir.
Power Button Not working after screen replacement
I recently changed the screen on 2 Motorola Moto X pure edition, Because it was cracked but after replacement the power button doesn't work anymore. I wonder if that could be a defect on the screen I bought. Or if I did something wrong. I followed a online guide changing everything. And Both screen bought from the same seller won't power on. It does light up when I charge just not able to tun it on. what do I have to do ?
Bu iyi bir soru mu?
Puan 1
1 Yorum
Did you ever figure this out or solve it?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I had the same problem - my power and volume buttons stopped working after replacing the battery.
Refer to step 8 here, specifically the 2nd screenshot (2 of 3). I had to reseat my power/volume flex - I did not have to reseat the connector to the board.
The 2nd screenshot shows a cable that could have come loose. Mine was glued down and taped, but had still come loose (probably while heating the phone up to take the back plate off).
I used long thin pliers to peal the clear tape, reseat the flex, and put the tape back on again. The phone works great now!
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Same problem and same resolution, but with Moto Z Force Edition. Thanks!
tarafından
Yorum Ekle
there is a small rubber cover on the upper left hand side of the back plate after you close the phone back up. If you remove the cover it exposes a ribbon cable and connector the you can push to connect back to the main board. There is another one near the bottom for the same purpose to connect the battery.
I found and reconnected the one near the bottom but I missed the connector in the top left. The phone exhibited similar behavior: screen lights up when plugged in but power button doesn't respond. Hopefully that is also your issue. Hope that helps.
Connector locations
Puan 1
Yorum Ekle
I have same problem,after screen replacement, but i dont know where is this place. Where is 2 from 3 screen? Please help.
Puan 0
Yorum Ekle
Yanıtını ekle
matheusphillipemuniz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 4,746
