Ana içeriğe geç
28 Temmuz 2014'te piyasaya sürülen Samsung Galaxy S5 mini; 8 MP arka kamera, 720p ekran, parmak izi okuyucu ve suya dayanıklılık özelliklerine sahip bir cep telefonudur. Büyük kardeşi Galaxy S5'e göre daha büyük bir ekrana, artırılmış pil kullanım süresine ve güncellenmiş bir kameraya sahiptir.
Microphone doesn't work very well when using speaker
Hi there! Sometimes when I send voice notes in WhatsApp my friends cant hear whatever I say, I thought that it was WhatsApp's problem until I made a call with the default phone app and turned on the speaker, whenever I speak 'normally', the microphone works correctly but when I use speaker, WhatsApp, Skype or similar apps (even in-game) the mic doesn't work
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
it uses a secondary microphone located at the top.. did you changed lcd?
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
No, I haven't but thanks for the info, I'm going to check if it is broken or anything, is there any other possible reason why it is not working?
tarafından Paylaş
dirty.. open it clean it. it will work. they just don't go dead..(maybe but not really).. if u need pics let me know. ill tell u how to,
tarafından Paylaş
Lol I got robbed the next day after I posted that comment. I found that this is a common problem, my friend's phone had the same problem so I tried buying a new mic and it didn't work so I decided to replace the whole display with the mic and speaker and it worked perfectly.
tarafından Paylaş
Yorum Ekle
What if the LCD has changed ? Does it affect the microphone, I bought this phone used so IDK what's replaced in it.
I opened it up and cleaned the mic ports now the bottom works well but the top is too weak.. and why does my phone switch to the top mic in loud speaker mode ?
Thanks
(Galaxy S4)
Puan 0
1 Yorum:
Loud speaker mode uses sencondary microphone, in ur case is slow bc the hole might have adhesive... open it up clean the adhesive and with the screw driver poke a biger hole.. that will fix ur problem with low secondary mic.. if the lcd is new... if is and old lcd its just dirty , try changing that mesh completely... best of lucks.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
rickyestrella95 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 1,095
