I drop my ps4 and the metalis damged
i was moving my ps4 and I drop it when I plug it in the disc drive was not working and the fan was making a loud Nosie I open the case you and the metal is bent any help
thanks
Bu iyi bir soru mu?
thanks
Bu iyi bir soru mu?
That looks pretty bent up. There is no way to know for sure without being able to test it but it looks like there is a good chance that you'll need a new fan (try to turn it with your had and see if it turns freely). Hopefully, the motherboard is OK. Many times when they fall the solder joints under the APU chip crack and go bad and/or the motherboard itself bends which makes it not work.
You'll definitely need a new metal plate but there's just no way to know for sure what else is wrong without being able to test it.
Bu yanıt yardımcı oldu mu?
were do i get a new metal plate from?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 324
1 Yorum
Can you add pictures to your post so that we can see the damage and advice better.
Conor Bailey tarafından
