2000 Jeep Grand Cherokee Laredo - want crank will turnover
I'm new at this trying to learn about autos.my brother has a 2000 jeep charakee he replaced a freeze plug now it want crank it will turn over
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I think your getting terms mixed up.
Cranking is typically what people mean when the engine turns with the starter motor.
Turning over is typically what they mean when the engine actually fires up.
Because you (or your brother) replaced a freeze plug, I suspect there is a disconnected or damaged sensor. The computer has to know precisely when to squirt gasoline and when to light the sparks - it does so via crankshaft and camshaft sensors.
For an engine to run, you need fuel, air and spark. And at the right time. Air is normally the easy one. Fuel you can sometimes smell. Spark you can sometimes measure (hard to do on the 4.7).
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 55
Whats the issue? If it cranks and turns over its fine.
Cameron tarafından
