Ana içeriğe geç
Haziran 2016'da piyasaya sürüldü; Avrupa'da A3003, Çin ve Kuzey Amerika'da A3000 model numarasıyla tanımlanır (https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/ adresine göre)
LCD + Frame Replacement
Third parties offer the LCD screen replacement with or without FRame assembly.
My question is , will the LCD + Frame assemblies include the two capacitive buttons? I believe it should because those two buttons are in between the two.
hence if i buy the Frame + LCD assembly then i would not need any heat to make the screen replacemnt.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Here is the link of the repair guide OnePlus 3 Ekran ve Sayısallaştırıcı Bloğu Değişimi
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
This doesn't answer my question...if I buy the LCD + Frame from a third party, do I have to take it apart in order for me to.install the two capacitive buttons?
tarafından Paylaş
yes, you have to salvage the button from the old screen.
tarafından Paylaş
Yorum Ekle
If you buy an LCD with the frame it should have the hardware buttons preinstalled as the hardware buttons are located between the LCD and the frame, all you have to do is connect the display, fingerprint and hardware buttons flex cables when reassembling the device. Remember the OnePlus 3's display should be an AMOLED panel and not LCD, make sure you pay attention to this when buying if you want the display to have the same quality as the original. :)
Puan 0
Yorum Ekle
Like Joseph said, make sure its Amoled not LCD. I accidentally bought a LCD replacement display. While functionally it works, it does not look NEARLY as good. It was quite a bit cheaper tho, around $50
Puan 0
Yorum Ekle
Yanıtını ekle
carlos sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 1,706
