Can I remove power steering pump pulley on my jeep 1999 cherokee
Can power steering pump pulley be removed without disconnecting power steering hoses?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
rob welsh, I believe you should be able to remove the pulley with out removing the hoses. 1st Link below has some info. and type of puller/installer kit required which may be available as a loaner tool or rental fee from local parts store, 2nd link shows a pulley being removed(may not be your exact vehicle) shows the motions. Belt naturally will have to come off and the fan shroud will probably have to be removed. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 2,068
