Ana içeriğe geç
Stoped working at all
My dolce Gusto stoped working when connected to electricity. Light does not even appear
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
8 Yorum
Does it work when its not connected? When did this occur? How long have you had it?
tarafından
My machine is only 5 months old. In 2 years I had 3 machines
tarafından
Hi got a Nescafé Dolce gusto machine and input a discaler through it yesterday as not running quite so smoothly . Did it and rinsed it through all ok. I went to use it and nothing the red light come on then the green been when it's a constant green unmove the swit h over to hot and nothing happens ? Any ideas
Thanks
tarafından
Have the same problem, how do you resolve it?
tarafından
ive had my Krups Piccolo Xs Manual Coffee Machine for 2 days i used it once now not working, no lights on, cant even take pods out it seems jammed? ive tried different sockets, assuming its not the fuse as its only couple days old, any ideas? please i need a coffee hahha
tarafından
3 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I think you should check your Dolce Gusto Genio’s mainboard(motherboard) or power port.
Then I think you could fix it.
Have a good day^^
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
looks like that signal form switch (hot water lever) goes to main board, but then what?
Maybe you know where should I start?
tarafından
I'm sorry, I misinformed you earlier.
Let me correct what I said earlier.
I think your Dolce Gusto fuse is broken so it doesn't working.
Here's a link to a YouTube video that tells you how to fix it.
Link : https://www.youtube.com/watch?v=aja0DsBO...
Link for your Dolce Gusto's fuse (SF129E) : https://www.amazon.com/SF129E-SEFUSE-Cut...
I hope you'll be able to repair it.
Have a nice day.
tarafından
ahh thank you for a suggestion, checked my fuses.
But all of them looks normal.
So still looking for my problem
tarafından
Yorum Ekle
it happened to me months ago and finally fixed it today. The on/off switch consists of a piece of conductive rubber that makes contact with the circuit underneath. In my case the circuit or rubber became misaligned or dirty.
Either way what fixed it was to disassamble the switch side carefully, remove the switch rubber, clean it and the circuit with some q-tips dabbed with alcohol and reassamble all.
Deassembly was the biggest pain.
Puan 0
Yorum Ekle
There are two thermal fuses in the back, above the boiler. Replace them both.
Puan 0
1 Yorum:
You’ll have to take it apart.
tarafından
Yorum Ekle
Yanıtını ekle
Suzan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 60
Son 30 gün: 176
Her zaman: 38,014
