Ana içeriğe geç
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Soru Tümünü görüntüle
Why does home button not work on new screen?
I replaced the screen on a iPhone 7 Plus and everything on the screen assembly works except the home button now. The home button does not seemed to be damaged. Everything worked before the screen replacement. The screen was shattered to the point that the lcd was broken so I'm not sure if that kind of damaged could of damaged the home button.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Could be an issue with the New Screen, if the cables are damaged of faulty then the home button just completely stops working even if everything else on the device is fine (found this out the hard way when removing a screen to do a new rear camera). Unfortunately you can't test this by trying a different home button to see if that also fails on that screen(which would be fairly cheap) because only the original button works in any capacity on the 7's so you'll probably need another screen to test.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thanks. I tried a new screen and the newer one worked.
tarafından
Yorum Ekle
Yanıtını ekle
Carlos Ramirez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 171
