Ana içeriğe geç
Repair process after water damage
Hi everyone,
So I am a noob in repair so i need some help.
I have two iphone 6 from my family i will be happy to fix them.
They fell in swimming-pool so they did not stay more than 45 sec or 1 min in water.
(I do not know exactly it is a long time ago like 6 months)
I will begin to fix which fell in W.C.
So the process to fix:
1)Dissassembly and look for corrosion
2)After put them (but which parts?) in alcohol 90%
3)Let it 3-5 hours to dry it
4)Assembly
5)Try to turn on
6)If it is not turning on,try to a new battery and lightning connector and maybe screen (which is the best order to replace?)
7)If nothing helps so it is the motherboard so it is dead?
I add some pictures because I do not see corrosion so I do not know which part first to replace because the corrosion...
So I put here the process if someone can tell me advices I am a noob.
And also the 3 questions I have I will be happy to receive advices.
Thanks in advance.
Bu iyi bir soru mu?
Puan 0
1 Yorum
Guys I am studying in university so I am busy
I will try in Friday
Thanks to everyone for the answers…
(I will go back and answer where I am maximum in Saturday night )
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
You need to remove the shields to get to the corrosion .Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning. Now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant.Dont use rice ! Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best
Bu yanıt yardımcı oldu mu?
Puan 6
3 Yorum:
Do you mind if I copy and paste your answer for future answers? I will reference your @jimfixer of course.
I will add the introduction to the answer as accordingly.
tarafından
Thanks @jimfixer. I followed your steps and ordered a new battery for $25 on amazon. My iPhone 6s powered up with some stripes across the screen (look like one of the digitizer connectors was really corroded and damaged). Anyway I was able to offload my images and do a complete backup. Thats what I was looking for just to save my data and pictures. By the way I stupidly did all the not to do steps (use hair dryer, leave in rice) before stumbling on this site and your instructions. Thanks again, you saved my memories.
tarafından
When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
Edit
tarafından
Yorum Ekle
Put the logic board in alcohol and get a new toothbrush, if you see corrosion brush it off gently. Peel off the black sticker where the power and touch ics are. Post pictures of the motherboard if anything looks not right.
Puan 4
Yorum Ekle
19/05 UPDATE Guys Today I tried to get the logic board out but in some steps I can't do it, the screws are so broken I am screwing for nothing...
I use a philips 0.2mm but the screws doesn't move.
In all this pictures from the tutorial almost all the reds are not moving and I am feeling it is going worse...
I thought it was my screwdriver that is broken but for the others it is working I thinks its the screws themselves that are broken
1)An advice?
Another questions I have 2 iphone 6 fell in water.
So I thought if i can "fusion" the best parts of each one to get one good iphone 6?
For example in the first picture we see how the battery is not good.d but the second iphone his battery is looking very well...
Another question this a way to test each parts if it s working separatly without dissassembly another iphone?
Because i see this battery it is looking good,In the logic board I will see later,the screen and the lightning connector I don't know how to test them...
2)An advice?
Puan 0
2 Yorum:
Anyone?In few days i wil get an iphone who stop working without any reason
again can i do a fusion with all the best parts of each phone ?
tarafından
Yes, but you will need to get those screws out first. Get a ifixit screwdriver, like the 64 bit driver kit, and try to remove them with the PH000 bit.
tarafından
Yorum Ekle
As it fall in water it does not mean it got corossion.
Most of the logic board part are not made from aluminium or silver or copper. So corrosion is not seen on your board. Only iron got corode fastly.
As your phone under water around 1 minute and it is power on condition so there are many lcd circuit channel shorted and many of ic cheap also got short and dead. so chances of fullly repairing of iphone is very less.
You should turn of your iphone as soon as it drop in water. Once water entered inside the iphone and touches logic board that means it is dead.
Puan -1
1 Yorum:
That is completely false.
tarafından
Yorum Ekle
Yanıtını ekle
Ta sœur Ensemble sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 40
Her zaman: 28,479
