Ana içeriğe geç
A 6 megapixel camera in Panasonic's Lumix series released in 2006.
5 Soru Tümünü görüntüle
I get the following message: Please Turn Camera Off
When the camera is turned on I get this message on the LCD: PLEASE TURN CAMERA OFF AND THEN ON AGAIN
My question is this how do I get it fixed and how much would the cost? Also another thing the lens does not close.
The camera is Panasonic Lumix DMC-FX3
Bu iyi bir soru mu?
Puan 0
2 Yorum
What do you mean by "is this has arrangement and how much would the cost?"
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Nereida Rivera-Calzada I agree with @danj that this is most likely a lens error ("the lens does not close."). I suggest that you start off by taking a look on here and see if any of that helps. Granted, most of the time it does not and the best thing to do would be a complete lens replacement. Here are the instructions for the disassembly of the camera and the lens. It is not as complicated as it may seem Disassembly Instructions
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
You'er the Man! @oldturkey03
tarafından
Yorum Ekle
Most likely your lens is stuck which is why the camera it telling you to turn it off and then on again hoping to clear the fault.
A stuck lens often points to a hard bang or drop. The other possibility is something sticky got onto the lens tube (soda or other surgery drink or food).
We don't do the service, all we do here is help guide you to either fixing your equipment if you feel you have the needed skills and tools or can guide you to the best place to get your equipment serviced.
In this case cameras are a bit tricky! I would recommend you locate the nearest Panasonic repair center by going here: Panasonic Support
Puan 2
Yorum Ekle
https://www.youtube.com/watch?v=qX3W2g7n...
Puan 0
Yorum Ekle
Yanıtını ekle
Nereida Rivera-Calzada sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 32
Son 30 gün: 115
Her zaman: 18,498
