Hi Randall,
It sounds like your Graphic chip on the laptop is busy dying, I might be wrong but lets test it, download PassMark BurnInTest http://www.passmark.com/ftp/bitstd.exe.
Install BurnInTest and launch the application the menu will pop up with an evaluation screen just click continue. Look for a tab at the top that says Configuration, and select "Test Selection and duty cycles".
Uncheck Optical Drivers, Printer, GPGPU, Disks, Sound and Network.
Make the CPU, RAM, Video, 2D and 3D Graphics all 100, press OK and then press the green triangle a lot of windows's will pop up don't worry about that, the tests have begun. It will run for a few minutes then a screen will pop up either flashing Green with PASSED or Red with FAILED.
Let me know of the outcome.
Ewald
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
2 Yorum
Same Thing Here On A MacOS! Please, Someone, Help!!
mrsmarty21 tarafından
I have the same problem on my acer chromebook model CB3-532
Jehail tarafından
