Ana içeriğe geç
Mavic Pro, Kasım 2016'da piyasaya sürülen, 4K video çekim özelliklerine sahip katlanabilir ve kompakt bir dronyur. Model numarası M1P ve kumanda modeli GL200A'dır.
Left rear arm support replacement part?
I had a small crash that bent up a small plastic support piece for the left rear arm.
The drone still flies, but that rotor isn't flying parallel to the ground anymore (even with some duct tape support): https://goo.gl/photos/xxZGB68M9ZvfhDt16
top view and rear view (broken support is covered in duct tape)
I found Where to buy replacement parts, but I can't tell if this part is part of the middle frame, upper shell, or bottom shell since it doesn't look like it's connected to the top or bottom shell.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Alright, I figured it out. That piece is called the saddle, and it's connected to the arm.
I can't find anywhere to buy just the saddle, but by searching "dji mavic pro left rear arm" on ebay I found an entire arm with an intact saddle for $30 with shipping.
It looks like you can also buy them from Cloud City Drones, but they're out of stock at the time of writing.
Will update when it comes in!
2017-07-18 edit: it came in! Confirmed that that piece is part of the arm. Replacement was pretty straightforward - just a bunch of screws and minimal soldering. Some parts of prying the case apart were tricky, but nothing harder than an iPhone screen repair.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
2017-06-12 Update: those two side plastic parts that come with the middle frame aren't the same pieces. I'm still trying to track them down.
Figured it out as I was typing out the question.
These side plastic parts are part of the middle frame, which you can buy on ebay by searching "dji mavic pro middle frame". I found a middle frame with two side supports for $15.
I imagine it would be easy to 3D print this part - it's just a flat piece of plastic with a hole in the middle.
Puan 2
1 Yorum:
Thank you so much! You just saved me hours of research. I just knocked my mavic pro out of the top of a 70' post oak with a dog ball thrower (that took awhile), and broke the left rear arm stop when I caught the drone. Going to look for a middle frame now!
tarafından
Yorum Ekle
Yanıtını ekle
Christian Genco sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 4,435
