T3 won't stay on.
bought a T3 for Christmas and it turns on, but won't stay on if you take your finger off power button. Any easy way to fix? Paid a lot for it to not work after 4 months.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
dzinegrafix, Could be a bad power button, loose broke wire/component or bad board. May still be warranted and if it is contact the manufacture for repair/replacement/refund. Below are a couple links that may help in disassembly of T3 and enable you to trouble shoot switch/connections/etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Bu yanıt yardımcı oldu mu?
I know this is an old thread, but I had the same problem. Did you ever find a solution? I tried swapping out the power button, but that didn’t work.
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 2,610
