Ana içeriğe geç
Mercedes W115 onarım kılavuzu, 1968'den 1976'ya kadar üretilen 200/200D, 220/220D, 230.4/230.6/240D, 250, 280, 300D modelleri ve çeşitli station wagon, coupe ve sedan varyantları dahil olmak üzere hem w114 hem de w115 modellerini kapsamaktadır.
replacing driver side check strap
I need to replace the door check strap in my 76 300d W115. Took door panel off, but you can't get the check strap out without taking the entire window assembly out, it appears to me.
am I missing something on replaceing, and what is the proper procedure to removing the window etc.
need some advice on this.
thanks
Philip
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@yadkin2002, Philip, I do not believe/not positive the entire window should have to come out to change the door strap, you should have to remove the pin and bolts and may have to turn(manipulate) the old strap to remove from door cavity or possibly have to loosen front window guide/track. Just to add a little to OT post, the video links(not your exact model) but may help in the removal of check strap. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=m3_NggBa...
https://www.youtube.com/watch?v=R0U3VNbb...
https://mercedessource.com/store/mercede...
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Philip sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 639
