Ana içeriğe geç
Bu Firestrike Elite Blaster 2013 yılında piyasaya sürülmüştür. Piston etkinleştirmeli ateşleme düzeneğine ek olarak, lazer güdümlü nişan alma özelliğine sahiptir. Blaster orijinal olarak mavi, beyaz, gri ve turuncu renklerde gelmiş olsa da, ikinci bir renk şeması turuncu, beyaz ve gri renkleri içerir.
Back screw will not budge
So I'm attempting to mod my first ever Nerf Gun. I decided to go with something relatively cheap; the Firestrike Elite.
However, before even getting to the inside of the gun, I've encountered a problem. The screw located under the top rails to the back will not move. I've successfully taken out all other screws, but this one will not budge. My screwdriver simply glances over the bumps of the screw, and I can never get a good hold on it. I managed to move it about a quarter rotation once, but that's it.
Can someone please give me some tips?
Thank you,
JR
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@dkinger, JR, Hopefully the screw head is not stripped. Try heating up the area with a heat gun/hair dryer right where the screw is threaded in, get it hot to the touch then try removing the screw. This should expand the area of the screw a little to allow for removal hopefully. The only other thing may to use a drill and small metal bit(a wee bit larger then O.D. of threaded portion of screw) and drill the head off screw and then disassemble and use small vise grips/pliers to turn out remaining screw shaft. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Justus Rodriguez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 1,130
