Ana içeriğe geç
HP Pavilion serisinin bir parçası olan HP Pavilion dv6000 dizüstü bilgisayar için onarım ve sorun giderme bilgileri. Nisan 2007'de piyasaya sürülmüştür.
does not work, screen not working
copied from PLEASE HELP! Beeping and black screen when laptop turned on
I am having a slimier problem mine was dropped once and is has not worked since, so there is little hope. when ever you plug it in all of the lights come on but the screen does not, also the fan comes on, you are still able to turn it off by holding the power button for a few seconds but it does not beep. when you unplug it it will turn off. please help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Is there any blinking sequences? I had a Pavilion that the CPU went bad on. The laptop would start but the lights would flash in a certain order every few seconds. It could be possible for many things on the laptop ended up breaking. Hard drives for example can be very easily damaged by impact. It could also be the screen might just have been damaged and you need a new one. It's very hard to determine the problem unless I'd be looking at it myself or unless it's throwing some codes indicating something is bad.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jake Bleck sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 509
