Ana içeriğe geç
Dahili T200 kod adıyla tanımlanan ve T250 kodlu makyajlı modeliyle birlikte Chevrolet Aveo'nun ilk nesli. Bu araç ayrıca Pontiac G3, Daewoo Kalos veya Pontiac Wave adlarıyla da satılmaktadır.
How to replace the AC condenser?
I went ahead and refilled the freeze on gas on the low pressure end of the vehicle refill pipe. A man told me to relieve the pressure from the high pressure end and continued to fill with freeze on on the low pressure end. The condenser turns on but no cold air comes out.
How do I change the condenser in this vehicle since it does not seem to be working ?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@jason5887, Jason, I take it you mean AC compressor. I will post proper charging procedure in a link below. Before changing anything your problem could be a leak in the AC system/bad relay/fuse/plug/wire/switch/etc. and should be checked for this, trouble shooting/repair links below may help solve your AC's issue.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.aa1car.com/library/ac98.htm
https://www.youtube.com/watch?v=pCv7rCdc...
https://www.youtube.com/watch?v=_Peb9o-L...
https://www.youtube.com/watch?v=Pdq8JAlc...
https://www.youtube.com/watch?v=w17DpGCc...
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Thank you so much I will go though these trouble shooting procedures and hopefully these solve the issue regarding the compressor.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Jason Mendez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 3,306
