What and where can I get the battery?
need a battery for my ae-1 canon camera. and what kind of battery?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Here's a little Vid on how to replace it: Battery Swap: Canon AE-1.
The original battery this system had was mercury oxide based which is no longer being made. You'll need a lithium Ion battery like a 6 volt Duracell X28LB
Bu yanıt yardımcı oldu mu?
Will the 6v battery impact performance or damage the camera?
You won't have any damage from using it.
But unlike the older battery LiOn batteries have a different voltage to current track so it won't power the camera as long.
Batteries Plus carries them. The one in my camera was the Energizer L544. Duracell model is the X28LB which is a Lithium-Ion Battery.
https://www.batteriesplus.com/productdet...
Make sure you only use a 6 Volt, there are a lot of similar sized batteries which are other voltages such as 3 or 12 volts. You do not want to ruin your camera.
tl;dr
You do not “need” a lithium battery. Alkaline or silver oxide are both cheaper, with silver oxide lasting longer than alkaline but probably not as long as lithium.
They each have different voltage discharge characteristics, but luckily the A-series cameras have voltage regulation (which is what makes alkaline OK to use here) so that the shutter works as long as possible and that the meter stays accurate until the camera shuts down.
explanation:
All Canon A-series models (and New F-1) use the same battery type, specified by Canon as either Alkaline or Silver-Oxide.
1) 4SR44 or PX28-S, modern silver-oxide replacement
2a) 4LR44, “28”, modern alkaline replacement
or
2b) four LR44’s (stacked together) are the same thing as one 4LR44 or “28"
3) PX28L, “28L”, modern lithium replacement
Just be aware that searching for one results in hits for the others, so pay attention to the actual chemistry if you care about that.
Depending on the model, the battery is checked by either observing a blinking LED, listening for rapid beeps, or looking at a needle in the viewfinder. Slow-flashing LED or slow beeps mean your battery is about done. On the AT-1, the needle will just keep registering ever lower during the battery check function.
Son 24 Saat: 9
Son 7 gün: 102
Son 30 gün: 354
Her zaman: 77,215
