Ana içeriğe geç
Repair guides for the HP Compaq 6910p.
15 Soru Tümünü görüntüle
Switching on but not booting
After I was done using my HP Compaq 6910p yesterday I decided to hibernate it, now I'm trying to on it but its not booting.
please what's going on?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum:
What happens when you press the power button? Does the screen light up? If so, what is on it? What version of Windows are you running: 7, 8., 10?
tarafından
the screen didn't light up (just like its not on) when I pressed the power button.
Its a windows 7
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Flea power is the common cause to this prooblem, basically what happens is when residual power that remains after the computer is switched off interferes with the system preventing with the boot process.
What you do
  1. Turn remove the battery
  2. disconnect adapter
  3. Press and hold the power button for 30 seconds
  4. Connect the power adapter without the battery
  5. Your computer should turn on now
If it doesn't this http://accatech.com/dell-inspiron-laptop...has more technical details, it might be about a dell laptop but i have used the same tips on other brands like hp and asus and it worked
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Flea power could be the cause of this issue you have. Sound like your laptop is fine but the screen is not turning on. Follow these steps below:
Turn the laptop upside down, loose the screws using screw driver then locate and disconnect the wire that connects battery and motherboard. Please be very delicate about it. Remove the battery then press power button for 30 seconds.
It will consume all the flea power left in circuits.
Then assemble the laptop as it was before and you are good to go. If you want more details follow this https://error24x7.tips/fix-laptop-screen...
Puan 0
Yorum Ekle
Yanıtını ekle
Omotoyosi Lawal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 2,060
