Ana içeriğe geç
This is a touch-screen controller associated with the Wii U video game console. It was released on November 18th, 2012, and available in black or white. Model number: WUP-010(USA)
region lock location on the motherboard
Hello ifixit community,
here is my problem;
I have a working motherboard with the wrong region and another one with a broken DRC-WUP graphic chip with the right region. I just want to solder the chip where the region lock is located to the working motherboard.
can someone tell me, where the region lock is located on the wii u gamepad motherboard?
Thanks for helping,
rgds Thomas
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I can’t confirm that.. I bought USA region mother board and took that chip from old board. Still wrong region gamepad. But.. I can’t be 100% sure that broken motherboard was EU region like my test console.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I found it out mysef. You just have to replace the U10 Micron 25Q256A 256 Mb Serial Flash with your original. Then you can use a motherboard with different region
Puan 0
1 Yorum:
This is not a permanent fix and the gamepad will only work with the Wii U console that the old Gamepad was paired with. This might be fine in the short term, but if anything forces you to re-pair the gamepad you will be out of luck. On that note, if you try and pair the gamepad to another Wii U, it will fail with error code "165-9901"
"The update cannot be completed using a Wii U GamePad designed for a different region."
tarafından
Yorum Ekle
Hi! You're gamepad is working??
Puan 0
Yorum Ekle
after installing the new motherboard, follow wiiu.hacks.guide to install aroma cfw and this will allow you to bypass the region lock via software
Puan 0
Yorum Ekle
Yanıtını ekle
Hannah Thomas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 2,878
