Ana içeriğe geç
After Display Replacement the camera wont turn on
Hello,
after I replaced the broken display of my PowerShot SX610 and putting the camera together again, it doesnt start anymore. Is there a hidden switch, which I have to push after the camera was open? And if yes, where is it located?
Thanks for your help and sorry for my bad english.
Regards Florian
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
I am having the same trouble right now
Any one with any idea?
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hello,
it is not easy to give an answer to this. As far as I know there are no hidden switches. If you only replaced the screen, there could be a problem with a power connector. Try disassambling the device, reassamble it again and check every single connector you opened. Are any flatcables upside down? Every flatcable pushed in place? Probably a broken cable (most times you can see this)?
Good luck, John
Puan 0
Yorum Ekle
Yanıtını ekle
Florian Bormann sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 52
