Ana içeriğe geç
An audio storage device that uses magnetic tape to record and play back audio input.
29 Soru Tümünü görüntüle
motor wont run when switched to forward or reverse
I have a teac tape recorder a-2050, when power is on , the vu meters lite up and if I activate one of the two micro-switches the motor runs,but if the long bar switch to allow the tape to play, the motor will not run, in the back I can see the relay pull in and thats the only indication that some thing is alive. I have worked on tv and radios with schematics but have nothing for this.
Duane
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Use a multimeter to test the switch. If you plan on keeping the machine consider buying the repair manual for it. I found this one on eBay: http://cgi.ebay.com/TEAC-A-2010-A-2050-A...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
These run on 4 idler wheels under the front panel that drives the capstan motor. They are probably gummy and deteriorated.
Puan 1
Yorum Ekle
Yanıtını ekle
kb9zqu2000 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 702
