Ana içeriğe geç
Repair information and support for the Acer Aspire E15 laptop, released from Acer in 2015. Model number: E5-575-33BM.
80 Soru Tümünü görüntüle
Acer Aspire E14 wont start up. It starts for 5 secs then shuts off
I was using my Acer Aspire E14 laptop when it suddenly shut down out of nowhere. I charged it until it's full. (The battery indicator lights are still working.)
But whenever I press start button, it doesn't turn on anymore. I can hear the mechanics inside start, but turn off immediately after about 5 seconds. Is it a fan failure? What could it be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum:
Thanks for the answers! The last time i used it before it shut off, i was watching a movie online and the laptop started to load slowly. I used an external fan for the first time (thinking the laptop will load fast) bcos it's very hot in our country. Several minutes after i removed the fan, it shut off and never turned on again.
I cant open / disect the laptop parts because everything is built-in. The battery and fan are not removable / replaceable. It's been with me for only 1 year now :(
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
The device is not POSTing. This essentially means that the BIOS is not initializing due to hardware failure. The issue is most likely motherboard failure in which case you may be better off getting a new device. It could be another hardware issue too, while unlikely.
Edit: Fixed my grammar.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
There may be signs of overheating, computer will shut off to protect itself and you. There may be a buildup of dust with in the fan, I suggest opening it up and blowing the dust out (some use compressed air available in a small can ). If this does not fix the issue, fan may have to be replaced.
Puan 0
Yorum Ekle
I have same kind of problem i thought it was black screen of death but its not . I was using this for power point i shut it down properly. Then i open it recently and i only hear fan and mechanics and very dark gray light then shuts . Im thinking if i need to replace new charger or batterry .brand Acer Aspire E14
Acer aspire E5-411-C1Y4
Puan 0
1 Yorum:
My laptop problem was lcd mine is more complex than E15
tarafından
Yorum Ekle
Problem on your laptop's bios chip
Puan 0
Yorum Ekle
Yanıtını ekle
Ana sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 4,822
