Ana içeriğe geç
Microsoft's third-generation Xbox game console, released November 22, 2013.
What is this thing?
What is this little metal pad here? There's a IC on it on iFixit's teardown but not on mine. 2015-1-4. I get E101, E102.
https://drive.google.com/file/d/1LQ_GP73...
Bu iyi bir soru mu?
Puan 3
7 Yorum
@tronicsfix sorry to bother you again, but you're the only one with console XP.
tarafından
Which little metal pad would you be referring to?
tarafından
@tronicsfix U5C5 in the middle of the photo.
tarafından
@pccheese you forgot how to add images right to your question?? That way, they will always be connected to this question. Your link will have long gone extinct, but iFixit will still be going strong.
tarafından
@oldturkey03 It's way easier to provide the link when using my phone.
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
There's nothing that's supposed to be there. If you look all over the motherboard there are pads similar to that. I'm not sure why but it seems there are different board configurations that they use. Different boards will have different empty pads and I'm not sure what the difference is.
Hope this helps.
Bu yanıt yardımcı oldu mu?
Puan 3
4 Yorum:
Thanks. Okay, does a HDD replacement normally fix E102/E101? Also, I'm replacing the HDD with an SSHD to upgrade it to an elite. Problem is I can't read the USER file within the support partition, and it's messing up everything. I've tried many windows programs and Linux, nothing works. I'll have to delete it and put a new one on it. Do you have a USER file you could upload so I may use it?
tarafından
Sorry, no I don't have that file.
tarafından
OK. One last thing, I hope. Do I have to copy all the files from the old HDD to the new one? What do I need to copy? I've already got the partitions cloned.
tarafından
E100, E101, E102 is normally something to do with software versions not matching from what I have found, You will need to replace the HDD with the software version currently on it, or an update-able version and boot to a thumbdrive to do the offline update.
tarafından
Yorum Ekle
That appears to be some kind of power regulator, deemed unnecessary and was cut from later productions.
It shouldn't cause console error.
Puan 1
Yorum Ekle
Yanıtını ekle
George A. sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 786
