Ana içeriğe geç
The OnePlus X smartphone was released in November 2015 by OnePlus. It is identifiable by model number E1005
Can I remove the vibration motor from my phone?
Hi, my phone's vibration motor is rusty around the 2 wires and vibrates continuously as soon as the phone is plugged. I am wondering if I could simply remove it? Does the phone work without the vibration motor, may I simply cut both wires?
The phone is a Oneplus X.
thanks
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If there are only two wires connecting the motor an now PCB board on the motor, then it should work. Can you solder of the motor? That would be better in case there would be a problem you could then solder the motor back on, but it should be no problem. Hope I helped you.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks, I removed the vibration motor and it works.
tarafından
Yorum Ekle
Yanıtını ekle
Paul-Emile Veuve sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,165
