Is there a way to capture the sllde show?
I want to demonstrate my drone at the local computer club. How can I capture the slide show to use on my computer while there? Thanks.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Licensing is not the issue. The question is HOW to capture the slideshow that is part of this teardown presentation. Users can print the screens for the article, but the slideshow automatically displays and I want to capture that.
No big deal. Worst case, I will stream it during the meeting. Problems can occur if the network is loaded, so I was looking for a way to save it to my computer and take it with me...
Bu yanıt yardımcı oldu mu?
I am sorry I totally misunderstood. I use Snagit to do a screen capture and it is a pretty good program and relative easy to use. I also used Camstudio which has some decent options. http://sourceforge.net/projects/camstudi... and then there is always the freebie http://www.nbxsoft.com/screen-recorder.p... which is very capable. Hope this is better then my last useless answer Of course all of these are for the Windows OS :) good luck
You'll need a slide converter such as one of these: http://www.amazon.com/s/?ie=UTF8&keyword...
You can also take your slides to your local photo shop and have them put onto a CD or DVD.
Then move the images into a presentation program such as Apples Keynote or Microsofts Powerpoint.
OK, I understand now. Hook up your computer to the projector so that it projects your desktop, go to the web site and run it. This way you run into no copyright infringements.
I didn't ask the question correctly. I want to capture the iFixit slide show off this site and use it in a demonstration for the local club...
alkoller, are you referring to the teardown of the drone? Check this out Content Licensing and if that does not answer your question try to contact ifixit via the support link that shows up when you check for parts. Good luck
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 1,522
1 Yorum
alkoller tarafından
