Ana içeriğe geç
The Bose SoundLink III, released February 2014, is the 3rd generation of Bose's SoundLink Mobile speakers. It is a modern, minimalist Bluetooth-capable portable speaker.
power indicator blinking red
I bought my SL iii last month, and yesterday when I use it, it can not be charged and power on.
When I connect the power cable, the power indicator blinking red always, and device can not be turn on.
What's the problem? Who can help me to solve it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 40
10 Yorum
Hello, I followed your instruction and,... YES!!!
So finally it works, thank you very much!!!
tarafından
tkx..mr. R...what steps did you have 2 follow....stay clean and safe
tarafından
Thanks this is a brilliant fix!!
tarafından
Thanks GUY WOLF! I've had my BOSE mini in a cupboard right through lockdown waiting for shops to open - then I came across this and it was fixed by the update.
tarafından
yes big problem blinking
tarafından
5 tane daha yorum göster
Yorum Ekle
14 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This is a bug with the firmware where the battery seems to get locked in low power mode if it runs down too far. I had this problem and tried every suggestion found online with no success. After much back and forth with BOSE support, the following finally worked:
1. Plug your speaker into a computer using the USB cable.
2. Go to btu.bose.com in a browser window. Download the software if you don’t have it and launch it.
3. The webpage should change to show it has launched. If it says there are updates available then choose to install them. This should fix it.
4. If it says the software is already up to date, then press the following keys in order: A,D,V,Up arrow, Down arrow. That should now give you the option to downgrade the software. Choose a downgrade and then Apply Changes.
That is what brought mine back to life. You can upgrade the software again after that.
Bu yanıt yardımcı oldu mu?
Puan 56
43 Yorum:
Tkx wolf guy ...also [a]read the instructions [b] if you bought it on line might have been of f long time --meaning takes 10/15 min. to get it to pair-also when first paring get away from other Bluetooth devices
tarafından
@Guy Wolf Thank you so much. Downgrading the firmware using your instructions was the only way that worked for me. Top man!
tarafından
There is no software for bose soundlink III. is there any way to fix this fu***** red and fast blinking battery problem with bose soundlink III?
tarafından
@Guy Wolf - i downgraded and the green light came on for about 10 seconds. Then started flashing red again. Then i upgraded and it did the same thing (but went red before finished upgrading). i've tried it a few times with the same results. Any other ideas? Thanks! Paul
tarafından
bose soundlink III specifically:
just for the record, there is not solution for this for the bose soundlink III.
There is no firmware avaiable for bose soundlink III online.
If connecting the power supply does not chrage the speaker and the light keeps flashing, you will have to send it in for service. They will change the battery. This is free under guarantee.
I know this because I have the bose soundlink III, had the same problem, went through all the advice online, and then had to send it in.
btw i was a little disappointed by bose service - they first asked me to download the firmware for bose soundlink III. I had to reply that this model has no download on their page, and they replied something in the way of "oh yeah, sorry, send it in then."
tarafından
38 tane daha yorum göster
Yorum Ekle
I had this problem to red light blinking ,I downgraded and its working ! But before you start you have to download current update on your pc
If the updater says that your device is up-to-date and you still have a problem, you can try to set it back to a former software version and do the upgrade again.
When it says there is no update available, you need to type the following keys: [a], [d], [v], [up arrow], [down arrow].
After that, you should be able to select a former software version and start the upgrade.
Puan 4
3 Yorum:
When I do this, there is no former update to choose from. It allows me to choose the same (current version) and that's all.
tarafından
Hi guys
after updating my Bose speaker it still came up with red flashing light? After reading the solution I then put in ADV up arrow down arrow and it sorted the problem out, at first it was confusing and I’m a technophobe I didn’t know where to type in the letters so I just did it (anywhere couldn’t see them ) and it worked it’s now charging with the amber light! Thank you guys really helpful
best regards
lee (uk)
tarafından
DIdn't work for me either. Same as Belar. Glad I bought this at Costco...
tarafından
Yorum Ekle
Try this first, if it fails, return it, it is covered under warranty.
1. Make sure your speaker is plugged into a working AC socket.
2. Check the connections between your speaker and the power adaptor.
3. Make sure you are using the power adaptor supplied with your speaker upon purchase.
4. If you are using a surge protector, check to see if it is working properly.
5. If you still cant get your speaker to turn on you may have a faulty power adaptor.
6. If your speaker is not charged or used within a 14 day period it with enter protection mode. Connect the speaker to the AC power adaptor to fix this issue.
7. Make sure the battery has sufficient charge to power on the speaker.
Puan 3
Yorum Ekle
Blinking Red indicates charge is needed. If the battery is drained it will continue to blink red while charging until there is enough charge. I would let it charge completely before trying to use it this time until the battery light turns green indicating battery is fully charged. If needed, you can do a SoundLink speaker reset, following these steps:
- On the speaker, press and hold MUTE for 10 seconds; the LED will flash briefly
-Press Power to turn the SoundLink back on
If either of these answers do not help, you may need to exchange it. Good Luck and please let us know... John
Puan 3
1 Yorum:
Mute is the speaker symbol with the line thru it
tarafından
Yorum Ekle
I’m having same issue with my Bose Soundlink Mini-2, did reset by pressing Power button (>10 sec) or pressing Multifunction button (>10sec…), doesn’t work, then luckily find this website, tried to do downgrading the firmware at but.bose.com…
The web page showing
Trying to key in [A], [D], [V], [up arrow], [down arrow], but seems nothing happened, did I missed anything here? Please advise … thank you!
Puan 3
7 Yorum:
Hey JC checking login
tarafından
email me 1boseguy@gmail.com
tarafından
Just typed answer for 10 minutes don’t post
tarafından
Type it in all CAPITAL LETTERS
tarafından
this does work I have done it may times. have you followed the video. is you Bose updater the latest version?
tarafından
2 tane daha yorum göster
Yorum Ekle
Had same problem - flashing red light. Tried reset (twice) no good. Removed battery (following ifixit guide) in preparation for replacing battery, but on a whim, reinstalled battery a little while later. Plugged in charger, and noted battery light now glowing (charging). All seems to be working again.
Puan 2
3 Yorum:
This worked for me!
tarafından
Ordered a replacement battery. Made in China. Reinstalled the Bose battery. Working so far. Hope it takes a charge. Still blinking red.
tarafından
The replacement battery made it so weird things like annoying beeps.
tarafından
Yorum Ekle
I took the suggestions and the last thing i tried was holding mute button. It turned on so i connected Bluetooth. It worked for a few seconds. Then completely turned off. I so give up. Does anyone know the address to return for repair/troubleshooting?? Tnks.
Puan 1
1 Yorum:
ebay upgrade the battery to 2330mAh=longer play time -$30
tarafından
Yorum Ekle
This update method didn't work for my SL 3.-.-
Puan 1
Yorum Ekle
my bose system is the soundlink wireless mobile speaker. It was unused for a few years, but later plugged in to only find out the battery maybe dead as the system didnt turn on and kept flashing red light. have tried it all but it doesnt work. The mute button brings it back to yellow Soild but soon starts flashing with red light. There are no firmware upgrades for my model. Now i have sourced a new battery but it still does the same. Left on overnight charge but in vain. Any solutions? Help needed
Puan 1
Yorum Ekle
Bose Bluetooth sound link speaker series I/ii/iii -plunge into charger 30/60 minutes-leave plugged in-hold down all the buttons xcept speaker for thirty seconds until all lights flash 30 seconds release/unplug/repeat/=red or amber should come on -24 hour charge
Puan 1
3 Yorum:
i tried with the instructions. Didnt work. Now which one is the speaker button. I have power, aux, BT, mute, up and down volume buttons, Did you mean do not touch the speaker but hold all the 6 keys down for 30 secs or more ? Tried that too. Red blinking light goes in 10 secs, turns to amber , soon to start flashing red again. Someone help me figure this out. The bose service center is no where closeby and i am wondering what could have gone wrong for this one to end up in coma
tarafından
People bose don’t care go to eBay buy a new battery series iii 2330mAh this number will give u bout 12/14 med volume higher the mAh more time same w/ i-ii the ii u need to do some soldering-online instruction
tarafından
Thank you so so much I tried everything and even bought a new battery and it it didn't want to charge only had yellow light turn on the it went red flashing. Your trick worked now I can enjoy my music again on my sound link 3. Don't give up guys this works. Thanks again.
tarafından
Yorum Ekle
Puan 0
Yorum Ekle
I have a Bose SondLink Mini. Flashing red light issue. Didn't use it for over a year but left it on the charging cradle. Do you think a new battery will solve this? The Bose updater is not recognizing the unit.
Puan 0
1 Yorum:
CosmoJr have gone thru all the resets that pertain to this unit..gscott
tarafından
Yorum Ekle
Likely not . I have tried that and tried to charge for long times still not working. Best place for it is recycling. Very disappointing.
Puan 0
1 Yorum:
No go thru my notes AJ===sell it on eBay =parts not working
tarafından
Yorum Ekle
Replace an upgrade battery 2330 mAh on eBay bout $23. make sure it reads bose—I’ve this issue countless times when I sell on eBay I’ve replaced the battery
Puan 0
Yorum Ekle
Yanıtını ekle
michael sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 65
Son 30 gün: 334
Her zaman: 73,607
