Everything works except digitizer after screen replacement.
I needed to just replace the charging port, I replaced it and the phones charges now. But then the digitizer didn't work so I ordered a new screen (LCD plus Digitizer) installed it and it doesn't work.
I have fixed a lot of iPhones, iPads and some samsung phones, so I'm not that new to this. I have searched a lot and can't find much more than the 2 first posts that come up on google.
Does any of you know how to fix this issue. I was replacing the charging port so that I could get some photos from the phone. The phone is password protected is there any way I could get the info out of the phone with my laptop?
Thanks
Bu iyi bir soru mu?
You should always test before you install the screen to avoid wasting time with faulty / defective parts which also causes warranty issues because some sellers void warranty if replacement part was installed.
Anyway sounds like digitizer ribbon cable got damaged / faulty part / connector for digitizer for damaged / not plugged in fully.
Charging port is fairly simple, don't really know how you made the digitizer not work after replacing the charging port.
Ben tarafından
