Ana içeriğe geç
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143 Soru Tümünü görüntüle
How can I recover data from undetected hard drive?
Hello,
Can anyone eloaborate what are the cases a hard drive not recognized by the sysytem and is there any way how to recover data from undetected hard drive?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you can't see it you can't recover it. If you tell us what it is and where, what operating system, how it is formatted we might be able to make some suggestions for recovery
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Hello There,
A hard drive not recognized due to either physical and logical damage.
  • Any damage in the head, platters, firmware etc.
  • Power surge
  • Was not safely removed can be one of the cause
  • USB Port is not ok etc.
In the logical case, data can be recovered from software. But, if the hard drive is not recognized that means you have compromised data.
But you can check once with data recovery experts.
Note - Check that your hard disk is visible in Disk Management or not?
Hope it will help you!!
Puan 2
Yorum Ekle
I have a similar problem, I have windows 7, when I start my laptop after some time it brings me to the screen where there is an option to select system repair or start windows normally. This happens everytime. When I click system repair, it keeps on loading the repair then freezes, if I click start windows normally, it goes to the windows loading screen and freezes. And I can't detect that hard drive from another operating system on the same laptop but different hard drive
Puan 0
1 Yorum:
Sadly, your drive has deeper problems. Time to replace it. If you have stuff on the drive which you must get off You'll need to send your drive in to a recovery service to see if the data is recoverable.
tarafından
Yorum Ekle
Yanıtını ekle
aaniya sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 1,797
