Ana içeriğe geç
HP Pavilion dv6500, 15,4 inç ekranı, şık kasası ve güvenlik parmak izi tarayıcısı ile uygun fiyatlı bir multimedya dizüstü bilgisayardır.
Display is completely black
When I start my notebook the display is completely black, I have already changed the inverter but the problem isn't resolved.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The problem can be the display, the graphics adapter or the mother board. If you connect an external monitor and it shows your desk top then you have a bad display. If you don't have an external monitor, use a flashlight angled to see if you can see icons on the desktop, this narrows the problem to a back light on the display. If none of these steps work, then you may have a bad mother board or bad graphics adapter. Shut down and remove all the memory and see if you get a beep error, a beep error will indicate that the mother board is working.
Bu yanıt yardımcı oldu mu?
Puan 1
10 Yorum:
I must remove RAM ?
tarafından Paylaş
This is to test to see if the motherboard is good, if you get a beep error then the mother board is good. Still could be problem with graphics adapter that is also on mother board.
tarafından Paylaş
If mother board is working, how do I identify the problem?
tarafından Paylaş
I have remove RAM and I listen a beep
tarafından Paylaş
What do you suggest?
tarafından Paylaş
5 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Piero Sabino sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 781
