Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Small light bleed on bottom of screen after replacing home button?
So I replaced the battery and the home button and everything works fine, however there's a small spot at the bottom of the screen that's yellow across white and white across black in that spot on the lcd. Looks like backlight bleed and if i press on the screen it gets bigger with pressure. Could I have tightened one of the screws too much on the home button? Is it worth reopening to see?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Perhaps the adhesive used under battery too thick?
Battery is pushing against screen?
Could be something under screen e.g a loose screw, home button cable getting snagged.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
but the screen has a protective metal plate between it. You mean between the plate and the glass, or under the plate where the home button is? It actually got a bit smaller since last night, you think it could get worse with time or damage the lcd?
tarafından
Under the home button itself. It might just go away and even itself out over time which is fine.
tarafından
Yorum Ekle
Yanıtını ekle
Gerard Dalbon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 3,472
