Ana içeriğe geç
The Nikon D90 is a 12.3 MP DSLR camera capable of taking photos and video.
40 Soru Tümünü görüntüle
Memory stick will not stay down
My Memory stick will not stay down. I push it in to take some pics and it pops right back up
Bu iyi bir soru mu?
Puan 0
2 Yorum
Thank you Very Much, I appreciate your help
tarafından
Daniel Austin, thanks for replying back, good luck with your camera.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Daniel Austin, Could be a broken piece off card/dust/debri or damaged inside the card slot mis-aligned lock spring/pin. Use a magnifier and aim a flashlight down the slot and see if there is anything obvious causing the issue. Also try another card if all looks good. If it ends up that the camera needs a new SD memory card slot, it is soldered to the mother board and would be best to have it checked out at a good local camera shop and estimate repair. Links below may be of some help, 1st/2nd link are forums that talks of your issue and 3rd link is video showing what he found to be the problem. Last link is a replacement card reader. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.thephotoforum.com/threads/nik...
https://www.flickr.com/groups/867288@N20...
https://www.youtube.com/watch?v=QMwO_Y0U...
http://www.ebay.com/itm/SD-Memory-Card-S...
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Daniel Austin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 231
