Ana içeriğe geç
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197 Soru Tümünü görüntüle
Do I necessarily need to re-calibrate my fans?
So, I have a dual 2.0GHz G5. The logic board died, so I'm looking to replace it. I've found one that has the same specs exactly.
So here's the big question: If I do a swap like this, will I need to re-calibrate the fans? Or will they remember what they were running at before and be okay?
Bu iyi bir soru mu?
Puan -1
1 Yorum
As a side note, I called Apple about possibly coming in to get the fans calibrated. They denied my request due to the "age of the machine". This may or may not be true of other stores, but it's definitely worth calling ahead in advance.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Your fans will go screaming off into the night without calibration. You will need either the original installation disk or ASD 2.5.8 to calibrate the fans.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
A buddy of mine has the 2.5.7 version... would that work, or do I absolutely need 2.5.8?
tarafından
Yorum Ekle
Yanıtını ekle
Josh Calvetti sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 2,770
