Ana içeriğe geç
The 2000-2006 BMW X5 models were the first generation (E53) of BMW's sport crossover years. The X5 was first released in 1999 for the 2000 model year and featured all-wheel-drive with either an automatic or manual transmission.
2003 X5 alternator replacement
specific r&r sequence for replacement of alternator. top down? bottom up? items to be removed
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
https://www.youtube.com/watch?v=5-9fVRJg...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Here are the steps for alternator replacement of BMW X5
  • Remove the drain plug on the driver's side bottom of the radiator
  • Drain the coolant and remove the coolant hoses
  • Loose the belt tensioner
  • Unhook the battery +/- connections
  • Unbolt and remove old alternator
  • Take the wires off the new alternator
  • Clean area where alternator goes, bolt the new alternator inside
  • Reattach coolant hoses and refill system with coolant
  • Put the intake tube and duct back on.
Puan 2
Yorum Ekle
For those who are changing alternator, it is not necessary to remove radiator as most DIY videos will instruct. It is a tight fit, but simply put cardboard protection against your radiator and you can wedge alternator up and out with no damage. It is a tight squeeze, but you can pull it out an put new one in without the extra wasted time pulling radiator out. I always look for short cuts on my vehicles when it comes to repairs.
Puan 1
Yorum Ekle
Yanıtını ekle
Dan McGough sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 77
Her zaman: 4,752
