Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
612 Soru Tümünü görüntüle
After water exposure, high fan speed
Water spill on my MB Air.
Replaced the logic board.
Batteries will not charge (a separate issue), so I start it up with the magsafe plug attached.
Boots like normal, but by the time it gets to the login page, the FAN IS RUNNING AT MAX.
The fan speed gradually increases over the first ~30sec after booting.
Any suggestions are greatly appreciated...
Bu iyi bir soru mu?
Puan 2
7 Yorum
Did you replace the thermal paste when you reassembled it?
tarafından
Good call Reed--that would've been a good explanation. But I DID use Arctic Silver when installing the new logic board.
tarafından
Ok. Well, I hate to do this to you, but I have no idea. Sorry I could't help.
tarafından
Not sure if this was the solution or if I got lucky with the timing:
I went ahead and reset the System Management Controller
https://support.apple.com/en-us/HT201295
And everything booted up appropriately after that!
tarafından
Well, as a side thought, there may be a thermal sensor somewhere on the board that is shot.
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check both sides of the trackpad cable, the trackpad PCB and I/O cable for liquid damage and burnt pins. If any of these have issues or are not recognised it will cause the fan to spin high speed.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Try changing the fan speed in settings.
Puan 1
Yorum Ekle
Yanıtını ekle
dcquickdraw sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 4,730
