Ana içeriğe geç
Saitek X52 Pro HOTAS (hands-on throttle and stick - gaz ve lövye el altında) oyun kumandası için onarım rehberleri. Bu kumanda Saitek tarafından piyasaya sürülmüştür.
Buttons Don't Work on stick
When I pull the joystick to the left the buttons work just fine. But if i pull my joystick to the right the buttons on the stick stop working any idea?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Do the buttons on the base still work, independent of the joystick position?
Do the LEDs still light up even when the buttons stop working?
If both answers are "yes", it's probably a worn PWM signal cable between the joystick and the baseplate. I'd suggest replacing it with some slightly tougher wire. I've made a guide a while back on imgur, I'm afraid. But it should point you in the right direction. It assumes you know how to solder, though.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Long time since last response nut i went thru cables on my joystick and all seem to work and conections checked with multimeter. so any advice?
Puan 0
1 Yorum:
Mine seemed fine with a multimeter when disassembled, but probably had some damage around the hinge. It fixed itself when I replaced the cable.
tarafından
Yorum Ekle
Yanıtını ekle
b00053195 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 2,192
