Dropped in water, works, but has lines
Dropped in water, I did the rice thing, my phones works perfect but has white lines.
Can I take it apart? And clean something
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@tgc let's start off by telling you that the rice thing does not work. It does not do anything but provide you with a false sense of security. It is an absolute waste of time and good rice.
I suggest you treat it just like any other water damaged device. The very first thing you want to do is to not try to restart, sync or otherwise use the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using this video. Remove all EMI shields from the motherboard. Then clean it with +90% isopropyl alcohol. Follow this guide , and even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. For as long as it has not been cleaned, you cannot properly troubleshoot your damage.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,069
