Ana içeriğe geç
Released in early 2015, the Canon PowerShot SX530 HS is a Wi-Fi enabled, super zoom camera. This camera weighs just under one pound. Identified by model number pc2200.
How to clean the dust inside of lens
How do you clean the dust inside of lens?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
4 Yorum
Is the dust on the lens glass or actually inside the lens?
tarafından
I have the same question and mine is on the inside of the lens
tarafından
It's inside the lens
tarafından
Well, to tell you the truth, I don't know. This is a tricky one. Try zooming in and out as fast as possible while shaking the camera to try loosening the dirt. If you have access to an air compressor, blow the lens out around the outside.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Dust rarely affects photos - if it does, it’s minor. In addition, you’re risking the entire camera over a little bit of dust.
You’re better off living with scratches and internal dust, rather then trying to fix it and risk ruining the lens and needing to replace the lens - or potentially the camera. With dust it doesn't affect resale as it's a common non-issue, but scratches that affect little to none of the final photo mean you can get a good deal on a nice lens or camera if you're able to test it and make sure it's not in a high impact area.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hello
First cotton buds and spray air duster and is done ✅
Good luck
Puan 0
3 Yorum:
Never use cotton balls on a lens! Lenses are extremely fragile, so you must think of something like cotton balls like fine grit steel wool. Canned air is fine as long as the gas liquid does not settle on the elements.
tarafından
Yes you are right
Good luck
tarafından
Still doesn't answer my question, how do I remove the lens to clean the dust out from the inside????????
tarafından
Yorum Ekle
Yanıtını ekle
Daniel Barnes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 2,910
