Ana içeriğe geç
QiCycle Katlanabilir Elektrikli Bisiklet, Xiaomi'nin e-bisiklet dünyasına ilk girişidir. Panasonic 18650 lityum bataryalarla güçlendirilmiş 250W yüksek hızlı bir motora sahiptir. Tork ölçüm sensörü ile birleştirilen Shimano Nexus 3 vitesli göbek, tek bir şarjla 45 km'ye kadar bisiklet gücü sunar. Ayrıca özel uygulaması aracılığıyla akıllı telefonunuza bağlanabilen bir yol bilgisayarına sahiptir ve elbette katlanabilir.
xiaomi qicycle battery replacement
where can i buy qicycle battery ? or how can i open the casing of the battery cause 18650 type is easy to find in my country.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
2 Yorum
With increased interest in e-bikes generally, the cost of replacement batteries needs to be addressed. Proprietary brand battery replacement costs can run up to $1,000. There needs to be a rebuild option and iFixit would seem to be a perfect forum.
tarafından
qicycle battery B157-1 I want to buy
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There are several telegram chats with battery mods.
I’m running with a mod that allow to travel with 2 battery at the same time and hot-swap between then without powering down the bike. I can reach +80km distance (6ah+12ah)
https://3dparts459136784.wordpress.com/
Actualización (17/08/19)
Xiaomi Qicycle Custom Mods
https://t.me/Qicycleteros
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Still guys your answers don’t address the question. seanjoeakiller wants to know whether one can just open the case and put in 20 cells in order to replace the old ones. That would be much cheaper and probably would cost around 100$ instead of 300+ that the full battery pack costs.
Update (09/20/2017)
Check step 17 here. Apparently, the battery case can open with some heating and "good vibrations" but you will probably break the one-time-use clips the case has in the process. However, if your battery is dead by now, it's the best thing you can try I guess and see if the case can be closed again after being opened before buying a brand new set of batteries with case costing $300.
Puan 1
1 Yorum:
qicycle battery B157-1 I have same battery but not charging can you repair
tarafından
Yorum Ekle
Resim
Resim
I fixed mine with a drill, once I saw back light flicker I put the charger on.
  1. Plug in the charger but Not to mains
  2. Using a drill spin front wheel until back-light fixed red
  3. Plug the power in. You will see everything is back.
  4. If your charger is flickering red, disconnect and do step 1
Puan 1
1 Yorum:
Hi did you spin the front wheel in the reverse way? Did you need to turn on the bike power to get back-light on?
tarafından
Yorum Ekle
Resim
Image above
Puan 1
1 Yorum:
How to release that casing batery ...give me step by step to do that..
tarafından
Yorum Ekle
https://www.aliexpress.com/wholesale?cat...
This is a link to a search for the battery on AliExpress, you can find many replacements, with prices starting at $219.99 (USD).
The real problem with repair or recreation of these batteries is opening the unit without damaging it. I'd love to be able to open the battery unit and test the cells to see if one is faulty and preventing further charging.
I'm a hair’s breadth from buying a replacement battery myself, as my battery won't charge anymore and Xiaomi don't support the cycle in my region. But that $219+ replacement price isn't a small amount, so I'm struggling on without the battery for the moment.
Puan 0
3 Yorum:
I removed the battery, opened its casing, and split the battery in two as then it was within the air transport laws (Australia). I don't recommend this unless you really know your electronics. The cells are spot welded in place and can get hot when removing. I never got it to work again..
tarafından
I have photos of seperated battery internals
tarafından
Definitely NOT user serviceable then?
No wonder they never used this style battery unit again.
Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
seanjoeakiller sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 68
Her zaman: 17,589
