Why is my charger not chargeing my batterey
Batterey not chargeing
Bu iyi bir soru mu?
Hello
Maybe the charger is damaged try to change another charger
Good luck
Bu yanıt yardımcı oldu mu?
Can you take plug of and put new on
Can u take apart the mains plug and put a new one on
Can some one let me now thanks
More likely it's the lithium battery pack that's the problem. Lithium powered devices have battery packs that govern the charging cycle and battery cells condition. They monitor the battery cells individually and determine the state of the battery. The plug in charger is a dumb AC or DC supply, does not monitor the battery, just provides raw power, usually 24 to 28 volts DC. End of battery pack life is determined by the software built into the battery monitoring circuitry and is a fixed parameter. The above comments also apply to other lithium powered device, drills etc.
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 1,649
