Ana içeriğe geç
Huawei'nin 2016 model amiral gemisi akıllı telefonu. Unibody bir kasaya ve Leica ile ortaklaşa geliştirilen çift arka kamera kurulumuna sahiptir. 32/64 GB depolama seçenekleri ve altı farklı renk seçeneğiyle sunulmuştur. Model numaraları EVA-L29, EVA-L19 ve EVA-L09'dur.
Mysterious setting reset and hotspot problem
Hey everyone!
Hopefully you can help me with a little problem:
My Huawei P9 fell. Now, no device can connect to its hotspot - two laptops and a phone say "Connection not possible", another phone falsely claimed "Invalid password entered" (and when i removed the password from the hotspot the error message switched to "Connection not possible" as well). The day before the fall hotspots were working just fine.
Also, each time I restarted the phone some settings were mysteriously reset. First I see a pop-up message reading "Some applications require data connection. We recommend hiring a data plan." - even though my provider is being recognized and I have working mobile data. Then, after every restart the 24-h-clock format, the percentage display of the battery, the auto-rotate and a lock-screen setting are reset to default. One time, I changed the SSID of the hotspot and after the reset it was just changed back to default.
After I took out the SIM, I tested if the settings reset happens without SIM. It did not. After that it did not occur again with inserted SIM card, neither. However, the "You should get a data plan" pop-up still happens and the hotspot still doesn't work.
How can I fix this problem, or more specifically, make the hotspot work again? I have tried a bit with different APNs, but to no avail. I also did a network setting reset.
I am not even sure if the issue has to do with software or hardware.
Any help is very much appreciated, thank you! :)
Kind regards
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
4 Yorum
Good question, if this is solved, please @me,Thank you
tarafından
Same problem I am having...ny solution please fwd
tarafından
have the same problem
tarafından
My P9 is behaving the same. Solution??????/
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hello.
First thing I will recommend is reseting the phone to factory default.
Is any part of the phone broken? perhaps the part with the wifi network antenna. If this is the case, You will need the help of a technician. Get more help here DEVICETECK
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Hello!
I considered factory reset, but I am holding back until I haven't exhausted other possibilities - also, because I won't be able to save my data for the next two weeks.
The screen is quite broken, for a while already. Also, the power button was a bit wobbly at times from an earlier fall - so there might be some internal damage. I should stress however that there has been no visible outside damage from this current fall. I suspected the network antenna - but I can use Wifi and mobile data seemingly without issues, so can the network antenna be the cause if only tethering/hotspots are affected?
Thank you for your answer!
tarafından
Mobile phones usually have three network antennas. The GSM, the Bluetooth and the Wifi. I think the wifi network is affected. Wifi might still work on your device but hotspot may not. Try the reseting first. Hopefully you problem may be solvd.
tarafından
Yorum Ekle
Good day. Hope this will help.
No damege to my phone. All I did was restart the phone and my Wifi hotspot stoped working.
With the restart is messed up some settings.
Made a backup to sd card and reset the phone back to factory settings.
Did the restore from backup and checed hotspot, reset my password and its working fine.
Huawei P9
Hope this helps
Puan 1
Yorum Ekle
is there any other fix than factory reset?
Puan 0
Yorum Ekle
Yanıtını ekle
dimitri_schach sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 17,806
