Am I able to replace the horn switch without replacing the airbag?
I replaced my high and low horns yesterday which fixed a short occurring in the horns themselves (not sure if that makes sense). However, my initial problem still exists - my horn will engage randomly by itself (whether I am using the vehicle or not). Also, when I press the horn switch, it will often get stuck and continue being engaged without me pressing it. To get it unstuck, I hit the horn switch multiple times.
I assume the horn switch is what needs to be replaced. Am I able to replace the horn switch without replacing the airbag?
@tperdue , if you don't have this yet, it will help out a lot: http://www.gvrdeu.org/Honda%20FSM/Accord...
Bu iyi bir soru mu?
4 Yorum
@tperdue could be the horn itself or your switch. @parker_ what make and model is your vehicle? same as the OP?
oldturkey03 tarafından
@oldturkey03 2000 Honda Accord LX 2.3L
Parker tarafından
@parkerSince the horn switch goes through the steering column, it could be a problem with the cable reel. Try a couple of different steering wheel positions to see if that makes a difference.
That being said, you should check if you are entitled to a free airbag replacement. Your airbag could be a deathtrap.
http://owners.honda.com/service-maintena...
S W tarafından
