Ana içeriğe geç
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Soru Tümünü görüntüle
data transfer to new HD using external HD
Upgrading HD on MacPro 2010 edition. If current (old) HD is backed up on external HD can the external HD be used to transfer data to new HD once installed?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Yes, but you really want to use Migration Assistant it will make the job much easier.
Here's a bit more on how it works: Move your content to a new Mac While the instructions are a bit vague you can also use it when upgrading a hard drive.
You'll want to get a 16 GB USB thumb drive and an adapter like this: Startech 2.5" SATA to USB adapter Follow this to setup your installer drive: How to create a bootable macOS Sierra installer drive. Put your new drive in then use the OS installer to boot up your system install a fresh OS onto your drive and do any needed updates at the end of the install process you'll be asked if you want to migrate your stuff over from a second Mac. Here we'll use your old drive connected via the adapter cable to recover your stuff.
But before you install your new drive make sure it's compatible!
Your system only has a SATA II (3.0 Gb/s) port so you'll need a drive that runs at this speed. Review your new drives spec sheet if you don't see SATA II (3.0 Gb/s) listed you'll need a different drive.
Here's the IFIXIT guide to install the drive MacBook Pro 13" Unibody Mid 2010 Hard Drive Replacement. You may also want to replace your HD cable as well as they tend to breakdown while you're at it. Here's the IFIXIT guide for that: MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement
MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Görseli
Kılavuz
Zorluk:
Kolay
30 minutes - 1 hour
MacBook Pro 13" Unibody Mid 2010 Hard Drive Görseli
Kılavuz
Zorluk:
Orta
15 minutes - 1 hour
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi,
I have the same machine and recently installed an SSD. I used an external hard disk to transfer all information. What worked best for me was to make a clone of my existing hard to the external drive and then clone it back to the SSD once installed.
I used Carbon Copy Cloner and it worked like charm.
Let me know if you need more detailed guide on how to do it.
Best,
Martin
Puan 0
1 Yorum:
Hold that thought! CCC has issues rebuilding the recovery partition! While a bit slower. Using the OS installer following this guide: How to create a bootable macOS Sierra installer drive and then using Apples Migration Assistant is by far the safest way to go.
tarafından
Yorum Ekle
Yanıtını ekle
jlweiss43 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 115
