Ana içeriğe geç
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
What does folder with question mark flashing and finder mean?
ibook g4 12
I own an ibook g4 but when i power it on i get a grey screen with a folder flashing a question mark and the finder face, does anyone know how I can fix this? please help !!
Bu iyi bir soru mu?
Puan -1
1 Yorum
Please give us the Axxx number located on the back of your Book. The speed would also help, then we can direct you to the correct guide.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The flashing question/finder face means the computer can't find an OS to boot... This can be caused by a corrupted install, a bad harddrive, or a few other things... Basically, you have to wipe out everything and re-install... How old is the hard drive in it?
Bu yanıt yardımcı oldu mu?
Puan 2
9 Yorum:
You don't have to wipe everything. First start up from your system installation disk and run disk utilities to see if you can repair your drive.
tarafından
Der... Forgot... I would highly suggest wiping it completely out though, unless you have a ton of photo's and movies/music on it
tarafından
Skippy - If the Disk Repair fails what other steps can the OP do before wiping everything? Then what to do if the (what kind of wipe?), fails?
tarafından
Is this a test?? If the disk repair fails, I would try target disk mode to make sure it's not the hard drive. If he goes for a wipe, zero out the data and go with the recomended disk format for which ever OS he decides to use.
tarafından
+ Not a test, just trying to get you to think and give a more complete answer. I couldn't give you an upvote the way it was. Now I can. Next step is replacing the hard drive.
tarafından
4 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Stranga sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 4,028
