Ana içeriğe geç
This computer was released by Asus in 2014.
How do I reinstall the system?
I want to reboot my computer, it's slow and the storage is full, even though I don't have much stuff on there. How do I reboot it? I've done it once before, but it was long ago, so I can't remember. The computer is a bit over a year old.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
6 Yorum:
What OS version do you have installed?
tarafından
I have Windows
tarafından
Did you empty your recycling box?
tarafından
Hi @@feliciaspyan using windows 10 ? If so there is should be option by the OEM inside to reset your pc.
Try This
https://www.laptopmag.com/articles/reset...
tarafından
How do I reset it without logging in
tarafından
1 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
As indicated by Augustine, use the link to laptopmag.com.
MAKE SURE YOU HAVE ANY FILES YOU WANT TO KEEP/SAVE COPIED TO A SAFE LOCATION (thumb drive, external hard drive, DVD ROM, etc).
  1. Click Start
  2. Type in "Settings" and click "Settings"
  3. Click "Update and Recovery"
  4. Select "Recovery" from the left-side menu
  5. Under "Reset this PC" click "Get Started"
  6. Make sure your files are backed up, select "Remove Everything"
  7. Click the "Just remove my files" option - This should be sufficient for your needs
  8. Click "Next"
  9. Click "Reset"
  10. Click "Continue"
I believe from this point, you should be back to square one and the initial Windows 10 setup wizard will walk you through the rest of the setup.
If you get stuck, don't be afraid to ask more questions.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
  1. turn power On
  2. press F9 many times. You will have recovery mode.
Puan 0
Yorum Ekle
Je vs conseil de faire une nouvelle installation c'est plus sécurisé
Puan 0
Yorum Ekle
Yanıtını ekle
Felicia Birgersson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 8,263
