Ana içeriğe geç
The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
310 Soru Tümünü görüntüle
Boots to Apple logo then nothing
Hello all, i hope you can help. I have an iPad 3 Wi-Fi/AT&T that will not fully boot into the OS. It boots to the Apple logo than straight to black screen. I've tried resetting (home +lock/power) a few times, let the battery drain as far as i can tell, let it charge still nothing. Anyone have any ideas?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Plug it into a computer and open up iTunes. Hopefully it does not say it has detected an iPad in recovery mode.
You may be able to get away with just updating the iPad in recovery mode to keep the data without wiping the user data on the iPad otherwise you may need to restore the iPad in the end.
You can either use 3Utools (Windows application) or iTunes to do this.
More information on how to put an iDevice into recovery mode and do an update system software instead of restore:
https://support.apple.com/en-au/HT201263
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
It's not even being detected in iTunes. On a Mac so i can't use 3UTools
tarafından
Did you try booting it to recovery mode? You need to keep holding the home button once it shows the apple logo and is plugged into computer.
tarafından
Yorum Ekle
Yanıtını ekle
Hunter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 62
