Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
iPhone has vertical black lines why won't it update/restore?
Hey all!!!
The iPhone won't update. It won't progress past the point shown in iTunes/the phone in the pictures attached.
I have tried updating with the screen off, with a different original screen, a new battery inserted.
It did at one point restore, but then it turned off and started boot looping with vertical lines showing up on the screen.
Any help appreciated!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
What happened between the phone working well and the failed update? Is the phone still boot-looping?
Try these things (if you haven't already) to see if anything helps:
  • Try a hard reset (Home & Power button for 10 secs)
  • Use a genuine Apple Lightning connector
  • Use a genuine Apple charging brick and let it charge overnight
  • Try to connect it to different computers (mac/pc if possible) with an updated iTunes
  • Put the phone in recovery mode (search DFU Mode). Careful, this can reset your data
  • Use 3uTools for putting it in and out of Recovery Mode
  • Use 3uTools to flash the firmware (you can't downgrade)
  • Check the condition of all the flexes (with magnification)
  • Disconnect the Front Camera Ribbon from the logic board and reboot your phone
  • Disconnect the screen assembly completely and see if iTunes will recognize the phone.
Otherwise, you may have a logic board issue. If you are uncomfortable doing these steps, consider finding a repair shop to do the troubleshooting. A shop that also does micro-soldering can go deeper if the problem is not modular in nature.
Get back to me with your observations by commenting on this answer.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
i am also having this problem..were you able to find a solution??
Puan 0
Yorum Ekle
Yanıtını ekle
kenn millard sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 653
